- MPQ76300FS-AEC1
MPQ76300FS-AEC1
MPSafeTM, 24-Channel, 100mA, Smart Linear LED Driver with Digital AFC, AEC-Q100 Qualified
The MPQ76300FS-AEC1 is a 24-channel, smart linear LED driver. Each channel is rated for up to 100mA of current, and 32 ICs can be cascaded together to create a 768-channel solution. The device is optimized for animated or dynamic lighting applications. It employs a 12-bit pulse-width modulation (PWM) dimming register and a 6-bit analog dimming register for each channel, enabling individual channel control. The 24 channels can be assigned to up to 4 different groups with independent dimming frequencies and duty cycles. The LED current (ILED) ramp rate and phase shift between channels during PWM dimming can also be digitally configured. The MPQ76300FS-AEC1 is designed to function across distant PCBs with a robust high-speed UART over CAN interface.
The MPQ76300FS-AEC1 features digital adaptive feedback control (DAFC) to maximize system efficiency and thermal performance. An integrated 8-bit analog-to-digital converter (ADC) can sense the LED string voltage (VLED) so that the pre-regulator's or buck voltage regulator's output voltage can be adjusted based on this sensed voltage. Voltage across the channels can be minimized to a value based on the headroom voltage.
Built-in self-testing (BIST) is implemented to perform self-diagnosis on critical analog and logic functions. It is developed under MPS's advanced MPSafeTM Functional Safety Product Development process, which has been independently certified to meet ISO 26262 guidelines. Protection features include LED open and short protection, ISET pin open and short protection, and over-temperature protection (OTP). If a fault condition occurs, the fault indicator (/FS) pulls low, and a matching fault register is set. A limp home state indicates if communication is lost.
The MPQ76300FS-AEC1 is available in a TQFP-48 (7mmx7mm) package, and is AEC-Q100 qualified.
- Easy Scalability:
- 24 Channels, 100mA/Channel
- Can Cascade Up to 32 ICs for Up to 768 Channels
- Supports Channels in Parallel
- Pin-Configurable Device Address
- 12-Bit Pulse-Width Modulation (PWM) Dimming
- 6-Bit Analog Dimming from 0% to 100%
- Supports 36V Load Dump
- -40°C to +150° Operating Junction Temperature (TJ)
- Cooler Thermals and Optimized Efficiency:
- Digital Adaptive Feedback Control (DAFC) Optimizes Pre-Regulator Output
- 400mV Headroom at 100mA
- Robust Communication:
- 2Mbps CAN-Compatible UART Interface
- Up to 64-Byte Read/Write Command
- Multi-Cast Write for Multiple Devices
- Configurable Watchdog Timer
- Optimized EMI/EMC:
- Configurable Phase Shift and Slew Rate
- Frequency Spread Spectrum (FSS)
- Selectable PWM Dimming Frequency
- CISPR 25 Class 5 Compliant
- Additional Features:
- Multiple-Time Programmable (MTP) Memory
- 2 Analog-to-Digital Converters (ADCs) for LED Binning and Negative Temperature Coefficient (NTC)
- Available in a TQFP-48 (7mmx7mm) Package
- Functional Safety:
- Built-In Self-Testing (BIST)
- FMEDA and Safety Manual Available
- Limp Home Mode
- Failsafe (/FS) Pin
- LED String Short (to GND or Battery)
- LED String Open
- VBIAS Low Voltage Warning
- Thermal Warning and Shutdown
- ISET Pin Open/Short Protection
MPQ76300FSGFN-xxxx-AEC1-T MPQ76300FSGFN-0000-AEC1-T
MPQ76300FS-AEC1 Resources
LED驱动器产品类目 -
MPQ7228-AEC1产品16 通道灌电流 LED 驱动器,带自适应反馈控制 (AFC) 和 UART 接口,符合 AEC-Q100 标准
MPQ4425C-AEC1产品36V、1.5A、2.2MHz、高效率同步降压 LED 驱动器,符合 AEC-Q100 认证
MPQ7230-AEC1产品42V、1.2A同步升降压/ 3A 降压汽车红外 LED 驱动器,符合 AEC-Q100 标准
MPQ7225-AEC1产品具有自适应反馈控制 (AFC) 的 16 通道灌电流 LED 驱动器,符合 AEC-Q100 认证
MPQ7200A-AEC1产品410kHz、42V、1.2A 升降压/ 3A 降压同步 LED 驱动器,带频谱扩展(FSS)功能,符合 AEC-Q100 标准
MPQ7235-AEC1产品36V, 3A汽车级同步降压红外 LED 驱动器,符合AEC-Q100认证
MPQ2484-AEC1产品具有多种调光模式的 75V、多拓扑 LED 控制器,符合 AEC-Q100 认证
MPQ7200-AEC1产品42V/1.2A 升降压或 3A 降压同步 LED 驱动器,符合 AEC-Q100 认证
MPQ24833-B产品工业/汽车级 55V、3A LED 驱动器,符合 AEC-Q100 认证
MPQ4425B-AEC1产品1.5A、36V、400kHz 高效率同步降压 LED 驱动器,符合 AEC-Q100 认证
MPQ7220-AEC1产品6 路、每路最大电流为 100mA 的升压 LED 驱动器,符合 AEC-Q100 认证
MPQ4425A-AEC1产品高效率 1.5A、36V、2.2MHz 同步降压 LED 驱动器,符合 AEC-Q100 认证
MPM6010-AEC1产品集成电感的汽车级 36V、1.5A、高效率模块、同步降压 LED 驱动器
MPQ2483A-AEC1产品55V、2.5A 可调频率 LED 驱动器,符合 AEC-Q100 认证
MPQ4425M-AEC1产品汽车级高效率 1.5A、36V、2.2MHz 同步降压 LED 驱动器
MPSCHOLAR
POWER MANAGEMENT FOR AUTOMOTIVE DISPLAY SYSTEMSMPSCHOLARThe automotive sector has indisputably felt the impact of the digital evolution, transforming how information is delivered to both drivers and passengers. Modern vehicles have shifted away from conventional analog dials and indicators to embrace dynamic, multifunctional, and interactive display systems. Along with enhancing the user experience and aesthetic appeal inside a vehicle, these innovatio...
MPSCHOLAR
LED DRIVERS AND POWER MANAGEMENT FOR LIGHTING SYSTEMSMPSCHOLARIn the past few decades, Light Emitting Diodes (LEDs) have seen a huge surge in their application within the automotive industry. When a voltage is applied, semiconductor diodes emit light through electroluminescence, which is the operating principle of LEDs. They are especially suitable for vehicular applications due to their small size, longevity, and efficiency. The LED assembly typically co...
MPSCHOLAR
INTRODUCTION TO AUTOMOTIVE LIGHTING SYSTEMS: EXTERNAL AND INTERNALMPSCHOLAROver the years, the evolution of automotive lighting has mirrored not only technological advancements but also the shifting landscape of consumer demands, design aesthetics, and regulatory mandates, culminating in a rich historical trajectory. Examining this path unveils how innovation, functionality, and safety considerations have collectively influenced the development of the vehicles navigating...
