- MPQ70170FS-AEC1
MPQ70170FS-AEC1
The MPQ70170FS-AEC1 is a power management IC (PMIC) designed to power a variety of processors and systems-on-chip (SoCs) used in automotive safety systems. It features five integrated synchronous buck converters and four low-dropout (LDO) regulators. The buck converters offer multi-phase operation, and four of the five buck converters can be configured as two dual-phase converters or one quad-phase converter.
The integrated 13 GPIO pins with multiple functions per pin provide flexibility for a variety of systems. The user-configurable state machine (UCSM), I2C interface with packet error checking (PEC), and integrated multiple-time programmable (MTP) memory allow for a high degree of configurability.
The MPQ70170FS-AEC1 is an ISO 26262 hardware-capable device developed under MPS's advanced MPSafeTM Functional Safety Product Development process, which has been independently certified.
The MPQ70170FS-AEC1 is available in a QFN-56 (8mmx8mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- Designed for Automotive Applications:
- Operating Input Voltage (VIN): 2.8V to 5.5V
- Operating Junction Temperature (TJ): -40°C to +150°C
- Reduces Board Size and BOM:
- Five Step-Down (Buck) Regulators:
- Output Voltage (VOUT) Range: 0.3V to 3.3V
- Output Current (IOUT): 4x 4A and 1x 2A
- Multi-Phase Operation Available for the 4A Bucks, IOUT Up to 16A
- Four Low-Dropout (LDO) Regulators:
- VOUT Range: 0.3V to 3.3V
- IOUT: 4x 350mA
- Bypass Mode
- Optimized for EMC/EMI:
- Frequency Spread Spectrum (FSS)
- Switching Frequency (fSW): 2.2MHz / 4.4MHz
- Phase Shift between Buck Regulators
- Application Flexibility via Configurability:
- Fast-Plus Mode via the I2C Interface with Cyclic Redundancy Check (CRC)
- Multiple-Time Programmable (MTP) Memory
- Configurable Power Sequencing
- Configurable Digital Inputs that Can Be Used as User-Configurable State Machine (UCSM) Trigger Sources
- Configurable Soft Start (SS) and Soft Shutdown
- Four 8-Bit Analog-to-Digital Converter (ADC) Channels
- Dynamic Voltage Scaling for Bucks
- PG Pin with Configurable Resources
- 13x GPIOs with Configurable Functions
- Additional Features:
- Backup Battery Input
- 32kHz Crystal Oscillator Driver
- Real-Time Clock (RTC) with Alarm
- Available in a QFN-56 (8mmx8mm) Package with 5mm Pitch and Wettable Flanks
- Functional Safety:
- ISO 26262 Hardware Capable
- Analog/Logic Built-In Self-Testing (BIST)
- Over-Voltage (OV)/Under-Voltage (UV) Monitoring and Over-Current Protection (OCP) on All Rails
- VIN Monitoring with Over-Voltage Protection (OVP)
- Thermal Warning and Shutdown
- CRC
- Interrupt Pin for Fault Reporting
- Reset Pin for System Reset
- Watchdog with Window and Q&A Modes
- Two Error Signal Monitors (ESMs)
- Clock and Bandgap Voltage Monitoring
- Documents Available to Aid ISO 26262 System Design
MPQ70170FSGQQE-xxxxAEC1-Z MPQ70170FSGQQE-xxxxAEC1-P MPQ70170FSGQQE-0000AEC1-Z MPQ70170FSGQQE-0000AEC1-P
MPQ70170FS-AEC1 Resources
PMIC (电源管理IC)产品类目 -
MPQ7928-AEC1产品MPSafeTM QM, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70150FS-AEC1产品MPSafeTM, 3 Bucks, 1 Boost PMIC, Optimized for Low-Noise Radar Applications, AEC-Q100 Qualified
MPQ7920-AEC1产品集成 4 个 2A/2.5A/4.5A/4.5A 降压变换器、5 个 LDO 的 5V PMIC,通过 I2C 和 MTP 进行灵活的系统设置,符合 AEC-Q100 认证
MPQ74202FS-AEC1产品带I2C 接口的MPSafeTM、2.7V 至 5.5V、四路 3A、同步降压变换器和双 LDO, 符合ASIL-D标准和AEC-Q100认证
MPQ7922-AEC1产品集成2.7V 至 5.5V、四路 3A、同步降压变换器和双 LDO的完整电源管理解决方案,具备I²C接口并符合 AEC-Q100 认证
MPQ70160FS-AEC1产品基于MPSafeTM开发流程的ASIL D级、6.5V、电源管理IC,集成6 个降压变换器(2路 4A、2路 3A 和2路 1A),适用于汽车 ADAS应用,符合 AEC-Q100认证
MPQ70240FS-AEC1产品基于MPSafeTM开发流程的21V、3W、4轨电源管理IC,具有3个降压变换器和1个LDO,适用于功能安全汽车 ADAS摄像头模块应用,符合 AEC-Q100认证
MPQ20082-AEC1产品40V, 300mA, Low Quiescent Current, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ79700FS-AEC1产品MPSafe™ 12 通道 ASIL-D 电源定序器,符合 AEC-Q100 认证
USE CASE
INTELLI-PHASETM 解决方案用例:中央计算机应用案例本用例将介绍 MPQ2946 和 MPQ86760 在自动驾驶汽车中央计算机中的应用。 MPQ2946 和 MPQ86760 为自动驾驶汽车的中央计算机提供了两种先进的电源转换解决方案,具备高功率密度、多功能性以及高度集成的设计特性。 自动驾驶汽车内的中央计算机承担着非常繁重的工作,例如实时数据处理、环境感测和监控,以及与运动控制有关的关键决策等。增加电源变换器的尺寸可以满足中央计算机所需的更高功耗和供电要求,但同时,笨重的电源变换器也会增加车身重量,从而降低车辆的整体行驶里程和性能。因此,汽车设计师们一直致力于寻找一种简单、又能适应中央计算单元强大处理能力的电源变换器设计。 MPQ2946 和 MPQ86760 为自动驾驶汽车的中央计算机提供了两种先进的电源转换解决方案,具有高功率密度、多功能性和高度集成的设计特性。MPQ2946 最多可配置为 8 相 3 轨运行,...
MPQ4374-AEC1产品40V, 12A to 16A, High Current Output, Synchronous Buck Converter with ZDPTM, AEC-Q100 Qualified
