- 汽车(车规级)
- 开关变换器和控制器(车规级)
- PMIC (电源管理IC)
- MPQ70150FS-AEC1
MPQ70150FS-AEC1
The MPQ70150FS-AEC1 is a low-noise, high switching frequency (fSW) power management integrated circuit (PMIC) optimized for powering monolithic microwave integrated circuits (MMICs) in automotive radar applications.
Features include three individual step-down DC/DC converters and one boost converter with excellent transient performance and high efficiency. The step-down DC/DC converters support configurable switching frequencies (fSW) up to 17.6MHz to enable low-dropout regulator (LDO) free, low-noise power solutions with minimal or no passive filtering. The configurable frequency spread spectrum (FSS) function can dither fSW for improved EMI performance.
The MPQ70150FS is an ISO 26262 hardware-capable device developed under MPS's advanced MPSafe™ Functional Safety Product Development process, which has been independently certified. Safety mechanisms such as built-in self-testing (BIST) provide high diagnostic coverage.
A configurable watchdog timer (WDT) is implemented with window and question & answer (Q&A) modes. Built-in voltage monitoring is featured for the input voltage (VIN) and output voltage (VOUT) rails. An additional voltage monitor is included to monitor an external rail.
Protection features include input and output under-voltage lockout (UVLO), over-voltage protection (OVP), under-voltage protection (UVP), output short-circuit protection (SCP), and thermal shutdown (TSD). SPI and I2C digital interfaces, as well as a one-time programmable (OTP) memory, are integrated for easy configuration and flexibility.
The MPQ70150FS requires minimal external components, and is available in a thermally enhanced TQFN-28 (5mmx5mm) package. It is AEC-Q100 qualified.
- Configurable Voltage Rails for Radar Monolithic Microwave Integrated Circuits (MMICs):
- 3x Configurable Buck Converters:
- Output Voltage (VOUT): 0.8 to 1.9V @ 17.6MHz
- VOUT: 0.6V to 3.3V @ 2.2MHz
- Output Current (IOUT): Up to 3.5A
- 1x Boost Regulator Outputting 5V @ 500mA
- Configurable Sequencing
- Dynamic Voltage Scaling (DVS)
- Superb EMI, Noise, and Ripple Performance:
- Switching Frequencies (fSW): 2.2MHz to 17.6MHz
- Advanced Frequency Spread Spectrum (FSS) Techniques
- Ultra-Low Noise Performance
- Built for Functional Safety:
- Reset, Fault, and Interrupt Pins
- External Voltage Monitor
- Window or Q&A Watchdog Timer (WDT)
- Short-Circuit Protection (SCP), Over-Current Protection (OCP), and Over-Voltage Protection (OVP)
- Redundant Bandgap, Clock, and VCC
- Thermal Warning and Thermal Shutdown (TSD)
- Built-In Self-Testing (BIST)
- Protected Memory and Registers
- ISO 26262 Functional Safety Certified
- Additional Features:
- 3V to 5V Input Voltage (VIN) Range
- Mount-ID Detection
- External Clock Sync In/Out
- SPI or I2C Interface with Cyclic Redundancy Check (CRC)
- Available in a TQFN-28 (5mmx5mm) Package with Wettable Flanks
- MPSafeTM – Developed for Functional Safety Applications: ISO 26262 Compliant
MPQ70150FSGUTE-xxxxAEC1-Z MPQ70150FSGUTE-xxxxAEC1-P MPQ70150FSGUTE-0000AEC1-Z MPQ70150FSGUTE-0000AEC1-P
MPQ70150FS-AEC1 Resources
PMIC (电源管理IC)产品类目 -
MPQ7928-AEC1产品MPSafeTM QM, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70170FS-AEC1产品5.5V, MPSafeTM PMIC with 5 Bucks and 4 LDOs for Safety-Relevant Applications, AEC-Q100 Qualified
MPQ7920-AEC1产品集成 4 个 2A/2.5A/4.5A/4.5A 降压变换器、5 个 LDO 的 5V PMIC,通过 I2C 和 MTP 进行灵活的系统设置,符合 AEC-Q100 认证
MPQ74202FS-AEC1产品带I2C 接口的MPSafeTM、2.7V 至 5.5V、四路 3A、同步降压变换器和双 LDO, 符合ASIL-D标准和AEC-Q100认证
MPQ7922-AEC1产品集成2.7V 至 5.5V、四路 3A、同步降压变换器和双 LDO的完整电源管理解决方案,具备I²C接口并符合 AEC-Q100 认证
MPQ70160FS-AEC1产品基于MPSafeTM开发流程的ASIL D级、6.5V、电源管理IC,集成6 个降压变换器(2路 4A、2路 3A 和2路 1A),适用于汽车 ADAS应用,符合 AEC-Q100认证
MPQ70240FS-AEC1产品基于MPSafeTM开发流程的21V、3W、4轨电源管理IC,具有3个降压变换器和1个LDO,适用于功能安全汽车 ADAS摄像头模块应用,符合 AEC-Q100认证
MPQ79700FS-AEC1产品MPSafe™ 12 通道 ASIL-D 电源定序器,符合 AEC-Q100 认证
USE CASE
INTELLI-PHASETM 解决方案用例:中央计算机应用案例本用例将介绍 MPQ2946 和 MPQ86760 在自动驾驶汽车中央计算机中的应用。 MPQ2946 和 MPQ86760 为自动驾驶汽车的中央计算机提供了两种先进的电源转换解决方案,具备高功率密度、多功能性以及高度集成的设计特性。 自动驾驶汽车内的中央计算机承担着非常繁重的工作,例如实时数据处理、环境感测和监控,以及与运动控制有关的关键决策等。增加电源变换器的尺寸可以满足中央计算机所需的更高功耗和供电要求,但同时,笨重的电源变换器也会增加车身重量,从而降低车辆的整体行驶里程和性能。因此,汽车设计师们一直致力于寻找一种简单、又能适应中央计算单元强大处理能力的电源变换器设计。 MPQ2946 和 MPQ86760 为自动驾驶汽车的中央计算机提供了两种先进的电源转换解决方案,具有高功率密度、多功能性和高度集成的设计特性。MPQ2946 最多可配置为 8 相 3 轨运行,...
MPQ4374-AEC1产品40V, 12A to 16A, High Current Output, Synchronous Buck Converter with ZDPTM, AEC-Q100 Qualified
