- MPC24380-260
MPC24380-260
The MPC24380-260 is a four-phase, non-isolated, high-efficiency, step-down Intelli-ModuleTM power module with Quiet SwitcherTM Technology (QSTTM). It integrates driver MOSFETs (DrMOS), inductors, and output capacitors to provide high efficiency and a small footprint, which is ideal for server applications.
The MPC24380-260 can achieve up to 260A (65A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC24380-260 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, provides Accu-SenseTM current-sensing to monitor the inductor current (IL), and provides temperature-sensing to report the junction temperature (TJ).
The MPC24380-260 is available in an LGA-54 (9mmx10mmx5mm) package.
- Quiet SwitcherTM Technology (QSTTM) Limits Peak Switching Voltages
- Wide 3V to 8V Input Voltage (VIN) Range
- Up to 260A of Continuous Output Current (IOUTx)
- Accu-SenseTM Current Sense (CS)
- Temperature Sense
- Compatible with Tri-State Pulse-Width Modulation (PWM) Signals
- Over-Current Protection (OCP)
- Over-Temperature Protection (OTP)
- Fault Reporting
- Available in an LGA-54 (9mmx10mmx5mm) Package
MPC24380-260-T
MPC24380-260 Resources
MPS电子开关解决方案应用 -
INTELLI模块产品类目 -
MPC22158-130产品130A, 8mmx8mmx4mm, Dual-Phase Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC22164-A-130产品9mmx9.9mmx10mm、130A、2 相、高功率密度电源模块
MPC22165-A-170产品170A、2相、高功率密度 Intelli-ModuleTM电源模块,具有合规高电流密度和9mm x 9.9mm x 10mm小尺寸
USE CASE
MPQ8633A产品16V、12A、同步降压变换器,具有可调电流限、可调频率和电压跟踪功能
MP5026产品16V、20A、2.8mΩ RDS(ON)、热插拔Intelli-Fuse解决方案
