- MPC22164-A-130
MPC22164-A-130
The MPC22164-A-130 is a 2-phase, non-isolated, high-efficiency, step-down power module. It integrates driver MOSFETs (DrMOS) and inductors to provide high efficiency and a small footprint, which is ideal for server applications. The device has two independent outputs, which can be used separately or in parallel. It can achieve up to 130A (65A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC22164-A-130 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current sensing to monitor the inductor current (IL), and has temperature sensing to report the junction temperature (TJ).
The MPC22164-A-130 is available in an LGA-72 (9mmx9.9mmx9.7mm) package.
- Quiet SwitcherTM Technology (QSTTM) Limits Peak Switching Voltages
- Wide 4V to 16V Input Voltage (VIN) Range
- Up to 130A of Continuous Output Current (IOUTx)
- Accu-SenseTM Current Sense (CS)
- Temperature Sense
- Tri-State Pulse-Width Modulation (PWM) Signal Compatible
- Over-Current Protection (OCP)
- Over-Temperature Protection (OTP)
- Fault Reporting
- Typical Weight: 3.6g
- Available in an LGA-72 (9mmx9.9mmx9.7mm) Package
MPC22164-A-130-T
MPC22164-A-130 Resources
MPS电子开关解决方案应用 -
INTELLI模块产品类目 -
MPC22165-A-170产品170A、2相、高功率密度 Intelli-ModuleTM电源模块,具有合规高电流密度和9mm x 9.9mm x 9.7mm小尺寸
USE CASE
AN INTRODUCTION TO 5G AND HOW MPS PRODUCTS CAN OPTIMIZE A BASE STATION'S AAU AND BBU技术文章5G is a cellular network technology that is often referred to in conversation as a technological breakthrough that will make everything easier — from robot-driven surgeries, to videocalls, to the ongoing developments in AI. However, it is not always clear in these conversations what makes 5G so unique compared previous iterations, except for its faster speed. The article will provide a look at 5G...
VIDEO
VIDEO
MP4588产品集成功率 MOSFET 的 100V、0.8A 、高效率、同步降压变换器
USE CASE
热插拔保护器件用例:5G 通信应用案例本用例介绍MP5990 热插拔解决方案在 5G 通信中的应用。 MP5990是一款全集成的 50A 热插拔解决方案,它不仅可以提供丰富的保护功能,如输入电压 (VIN) 过压保护 (OVP)、输出电流(IOUT) 过流保护(OCP)、短路保护(SCP)和过温保护(OTP)等,还可以通过 PMBus 接口优化 5G 通信的电力传输。 向5G通信的过渡让蜂窝技术在联网设备的延迟、速度和容量方面有了巨大的进步。传统的热插拔电源模块已经难以应对 5G的高级功能,这些功能需要更高的额定电流和更快的电力传输,尤其是在功耗快速变化的情况下。强大的电源保护解决方案也是 5G 通信的另一个重要考量因素,因为无论短路、浪涌还是电压波动都可能导致代价高昂的停机,甚至损坏5G 数据中心和基站。 MP5990 是一款全集成的 50A 热插拔解决方案,它除了提供输入电压(VIN)过压保护 (OVP...
MP2927产品三路输出数字多相控制器,兼容用于AVSBus的PMBus 接口
USE CASE
INTELLI-PHASETM 解决方案用例:汽车高性能计算 (HPC)应用案例本用例将讨论MPQ86940和MPQ2977-AEC1在汽车高性能计算 (HPC) 中的应用。 MPQ86940 Intelli-PhaseTM解决方案与MPQ2977-AEC1多相控制器相结合,可用于设计具有数字控制的多相稳压器 (VR),实现高效率、自适应的功率传输,优化汽车 HPC 系统性能。 自动驾驶、无人驾驶出租车、软件定义车辆和 ADAS 等高性能计算任务中的汽车电源管理均依赖于HPC 系统。随着汽车 HPC 系统规模的不断扩大,功耗也随之增加,而由此产生的热量可能导致不少问题的产生,如组件损坏影响可靠性,冷却成本持续增加,以及碳足迹不断增高。在车辆工程和测试,以及支持高端信息娱乐系统和自动驾驶的机器学习算法中,汽车 HPC 系统的应用越来越广泛,提升汽车 HPC 的电源管理和效率也变得至关重要。 MPQ86940 Intelli-PhaseTM解决方案与MPQ2...
VIDEO
大电流 FPGA 和 ASIC 电源模块:MPM3698 和 MPM3699视频MPS 专为大电流计算应用设计的 MPM3698 和 MPM3699 电源模块具备出色的功能特性。这两款集成型电源模块能够以紧凑、高效的封装提供高达 160A 的输出,非常适合高端 FPGA、ASIC 和显卡供电应用。双输出 MPM3698 及其 12 相控制器可用作多相系统中的主设备,MPM3699则作为集成 4 相功率级对其进行补充。它们将控制环路、功率级和电感组合到单个封装中,以提高功率密度并简化设计,共同为电流需求超过 1000A 的应用提供了强大的电源解决方案。 相关产品详情页: MPM3698 MPM3699
