- MPC22158-130
MPC22158-130
The MPC22158-130 is a dual-phase, non-isolated, high-efficiency step-down power module. It integrates driver MOSFETs (DrMOS) and inductors to provide high efficiency and a small footprint, which is ideal for server applications.
The MPC22158-130 has two independent outputs, which can be used separately or in parallel. it can achieve up to 130A (65A/phase) of output current (IOUT) across a wide input voltage (VIN) range.
The MPC22158-130 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current sensing to monitor the inductor current (IL), and has temperature sensing to report the junction temperature (TJ).
The MPC22158-130 is available in an LGA-45 (8mmx8mmx4mm) package.
- Quiet SwitcherTM Technology (QST) Limits Peak Switching Voltages
- Wide 3V to 16V Input Voltage (VIN) Range
- Up to 130A of Output Current (IOUT)
- Accu-SenseTM Current Sense (CS)
- Temperature Sense
- Compatible with Tri-State Pulse-Width Modulation (PWM) Signals
- Over-Current Protection (OCP)
- Over-Temperature Protection (OTP)
- Fault Reporting
- Typical Weight: 1.2g
- Available in an LGA-45 (8mmx8mmx4mm) Package
MPC22158-130-T
MPC22158-130 Resources
MPS电子开关解决方案应用 -
INTELLI模块产品类目 -
MPC24380-260产品260A, Four-Phase Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC22164-A-130产品9mmx9.9mmx10mm、130A、2 相、高功率密度电源模块
MPC22165-A-170产品170A、2相、高功率密度 Intelli-ModuleTM电源模块,具有合规高电流密度和9mm x 9.9mm x 10mm小尺寸
USE CASE
MP5024产品16V, 20A, 2.8mΩ RDS(ON), Hot-Swap Intelli-Fuse Solution with PMBus Lite
MPQ8633A产品16V、12A、同步降压变换器,具有可调电流限、可调频率和电压跟踪功能
