Overview of Power Electronic Devices And Their Characteristics
Diodes, thyristors, and transistors play crucial roles as fundamental components in power electronic systems, enabling the handling and regulation of high power levels in electrical circuits. Single wafer diodes, for instance, exhibit an impressive capability to block over 9 kV across a wide temperature range. Thyristors, on the other hand, can withstand even higher voltages, surpassing 10 kV, while being able to conduct currents of up to 5 kA. Power transistors, while not as robust in terms of voltage handling, are still capable of reaching levels of 6 kV and 0.6 kA.
Diodes are electronic components that are used in electronic circuits to control the flow of electric current. They are made of semiconductor materials such as silicon or germanium. Diodes have a special property that allows them to conduct electric current in one direction (from the anode to the cathode) while blocking it in the opposite direction, this is known as the diode's "rectifying" behavior, and it makes diodes useful for various applications, such as in rectifier circuits to convert AC to DC power, voltage regulation, signal modulation, and protection against reverse current flow. Diodes possess crucial characteristics, such as low forward voltage drop, fast switching speed, and high reverse breakdown voltage, which makes them suitable for various power electronics applications. The forward bias behavior of power diodes is nearly linear, resulting in a voltage drop that is proportional to the ohmic resistance and current. This linearity enables efficient power conversion with minimal power losses during operation. Diodes also exhibit minimal reverse recovery time, allowing them to swiftly transition from forward to reverse bias, making them well-suited for high-frequency applications.
Here are some common types of diodes:
  • Zener Diodes: These diodes are designed to operate in the reverse breakdown region, where they exhibit a stable and specific voltage across their terminals. They are commonly used in voltage regulation circuits and overvoltage protection applications.
  • Schottky Diodes: These diodes have a lower forward voltage drop compared to standard silicon diodes, making them suitable for applications where low power losses and high efficiency are important, such as switch-mode power supplies and high-frequency circuits.
  • Silicon-Controlled Rectifiers (SCRs): These are four-layer semiconductor devices that act as controlled rectifiers, allowing current flow in one direction when triggered by a gate signal. They are commonly used in high-power applications, such as motor control and AC power regulation.
Thyristors are specialized switches that controls large amount of power. They are often used in high voltage and high current switching application suchbas motor control Some examples of thyristors include:
  • DIAC (Diode for Alternating Current): This is a bidirectional diode used in power electronics to trigger thyristors or triacs in AC circuits. It exhibits negative resistance characteristics and is commonly used in applications like dimmer circuits, motor speed controls, and AC voltage regulators to precisely control power levels.
  • GTO (Gate Turn-Off): A type of thyristor used in power electronics that can be turned off by a negative gate signal, providing precise control of power in applications like motor drives and power converters.
  • Triac: A triac is a type of bidirectional thyristor that enables control of current flow in both directions. It is equipped with three terminals: main terminal 1 (MT1), main terminal 2 (MT2), and a gate. They are widely used in power electronics to control AC power in applications like dimmer circuits and motor speed controls.
The firing angle of a thyristor, often denoted as α, is the angle between the instantaneous voltage applied to the thyristor and the point at which it starts conducting. It is used to control the timing of when the thyristor turns on and begins to conduct current in AC voltage control applications. By adjusting the firing angle, the average power delivered to a load can be controlled, allowing for precise control of the output voltage or current.
Transistors
Here are some common types of transistors:
  1. The BJT, or bipolar junction transistor, is a commonly used electronic component that serves as an amplifier or switch. It has three terminals - collector, base, and emitter - and operates through minority carrier injection and transistor action. BJTs are versatile and find applications in amplifiers, digital logic circuits, voltage regulators, and motor control. They are available in NPN and PNP types and are integral to modern electronics.
  2. A Field-Effect Transistor (FET) is a semiconductor device with three terminals - the drain, source, and gate - that regulates current flow between the drain and source by applying a voltage to the gate. The most common type of FET is the MOSFET (Metal-Oxide-Semiconductor Field-Effect Transistor), which features a metal gate separated from the semiconductor by an insulating oxide layer. FETs, particularly MOSFETs, are known for being voltage-controlled devices with high input impedance, low output impedance, and fast switching speeds. They are extensively used in digital circuits, amplifiers, and power electronics applications.
  3. The IGBT is a power semiconductor device that combines BJT and MOSFET characteristics, used for efficient power control in high-voltage applications. t has three terminals: collector, emitter, and gate. The IGBT operates as a voltage-controlled switch, similar to a MOSFET, but has the high current-carrying capacity and low on-state voltage drop of a BJT. Key properties of IGBTs include:
    • High voltage and current ratings.
    • Low on-state voltage drop.
    • Moderate switching speeds compared to MOSFETs.
IGBTs are widely used in high-power applications like motor drives, power supplies, and renewable energy systems.
Capacitors, inductors, and filters are also important components of a power electronic system. Capacitors are employed for energy storage and voltage stabilization. Inductors serve as magnetic energy storage and high-frequency noise filters. Transformers facilitate voltage level adjustments in AC circuits, either stepping up or stepping down. Filters are utilized to eliminate undesirable noise and harmonics from electrical circuits.
Power electronic devices possess distinctive features that render them suitable for specific applications. These features include voltage and current ratings, switching speed, power loss, and thermal performance. Power electronics engineers must carefully choose the appropriate power electronic devices for a given application to ensure optimal performance and efficiency.
