Battery Estimations
State Of Charge (SOC) Estimation
Definition and Significance of SOC
In the BMS’s context, SOC is a vital variable. The available or left capacity in a battery indicated as a percentage of its rated capacity, is known as SOC. In layman's terms, SOC is referred to as a fuel gauge for the battery, suggesting the amount of remaining energy before the need for battery recharge.
$$SOC(t)=\frac{Q_{remaining}(t)}{Q_{max}(t)} \times 100 [\%]$$
SOC directly affects the battery’s functional safety, efficiency, and lifespan, so it is important to understand this concept. With the assistance of precise SOC estimation, users can optimize their power management techniques and avert scenarios such as over-discharge or over-charge that could damage the battery.
Methods for SOC Estimation
Voltage-Based Method: To evaluate SOC, this is the easiest technique. The terminal voltage reduces when the battery discharges and offers an approximate estimation of the leftover capacity. Though, parameters like aging, temperature, and load currents affect the accuracy of this method.
Coulomb Counting Method: To calculate the remaining charge, this method calculates the current’s inflow and outflow. Although, this method is more precise than the voltage-based method, due to the inefficiencies and self-discharge, it is more prone to increased errors, which ought to be rectified periodically.
Kalman Filtering: Mathematical equipment employed for calculating parameters that can be measured indirectly and have noise is known as the Kalman filter. It is accountable for uncertainties and noise in the measurement and also offers precise SOC estimates.
Neural Networks: Stimulated by the human brain’s function, these complex systems can learn from data. SOC dependent on past charge and discharge cycles can be estimated by neural networks, resulting in an increased accuracy over time.
Electrochemical Impedance Spectroscopy (EIS): To estimate SOC, this technique applies a small AC voltage and observes the current’s response. For general BMS applications, it is one of the most precise methods. However, the involved challenges and price make it less popular.
Challenges in SOC Estimation
Multiple challenges come with SOC estimation. For example, SOC estimation becomes more difficult as battery behavior might change with time due to aging and usage. Moreover, the battery’s performance is affected by numerous environmental elements such as temperature and current rates that further add complication to the SOC estimation.
Battery Pack SOC Limits Estimation
Full SOC Estimation: The state of a fully charged battery indicates full SOC. Overcharging the battery could damage and decrease the battery’s life; therefore, to prevent overcharging, it is mandatory to have an accurate full SOC estimation.
Empty SOC Estimation: The state where the battery is fully discharged is known as empty SOC estimation. Battery damage and capacity loss can be caused by over-discharge that can be averted by proper estimation of empty SOC.
Pack SOC Estimation: The SOC estimation of a complete battery pack having multiple cells is critical to handle the pack’s well-being and performance effectively.
Applications And Importance Of Accurate SOC Estimation
Precise SOC estimation can lead to a huge variety of use cases. It tells the drivers about the pending range in electric vehicles. Also, it manages energy effectively in renewable energy systems. In the case of portable devices, it informs users till when they can utilize their devices before they need to recharge. Therefore, for any battery-powered system, the precision of SOC evaluation is important for secure, dependent, and efficient operation.
State Of Health (SOH) Estimation
Definition and Significance of SOH
An estimation that indicates the normal condition of a battery and its capacity to provide performance in comparison with its nominal performance when it was new is known as SOH. Usually, it is denoted as a performance in which a perfectly healthy battery with no capacity loss is represented by 100%. Due to parameters such as aging, usage, environmental circumstances, and charging cycles, a battery’s SOH will eventually reduce with time.
$$SoH(t)=\frac {Q_{max}(t)}{Q_{nominal}(t)} \times 100 [\%]$$
The SOH evaluation informs about the battery’s remaining useful life that can impact decisions like maintenance, replacement, and optimal utilization. Hence, it plays a vital role in successful battery management. An increased system’s dependability, cost reduction, and prevention of unforeseen battery failure can be the result of SOH’s correct understanding.
Methods for SOH Estimation
SOH evaluation can be done by multiple techniques, each having its own pros and cons.
Capacity Comparison: The easiest way to compare the battery’s current highest capacity to the one when it is new. This can be possible by doing a full charge-discharge cycle and calculating the total charge capacity.
Model-Based Estimation: In this technique, the mathematical or physical models are made that duplicate the battery behavior. The SOH can be calculated by adjusting these models to real measurement data.
Machine Learning Techniques: For SOH evaluation, machine learning technologies are skyrocketing with the rise of Artificial Intelligence. Procedures such as support vector machines or neural networks can make exact forecasts about battery health by examining the previous data.
Impedance Measurement: As the battery ages, its internal impedance rises. The battery’s health can be easily calculated by measuring the impedance and comparing it with baseline values.
Applications and Importance of Accurate SOH Estimation
For many applications, precise SOH estimation plays a crucial role. Decisions about the time for battery replacement, and optimization of driving for the battery’s life can be made possible by understanding the battery’s SOH in electric vehicles. The knowledge about SOH can lead to maintenance schedules and enhance the power supply’s reliability in energy storage systems. Understanding of the SOH can assist users manage their usage, and charging habits to extend battery life in portable electronics devices.
Users and system managers can elevate the battery’s life, enhance safety, and accordingly make decisions about battery usage and replacement by precisely measuring a battery’s SOH. Thus, in the BMS world, increasing SOH estimation techniques can continuously become a key focus.
State Of Power (SOP) Estimation
Definition And Significance Of SOP
At a particular point, the battery’s ability to provide or absorb a certain power is known as the State of Power (SOP). It is a function of the battery’s SOC, SOH, and functioning conditions (such as temperature and current). It can be defined as the ratio of peak power to nominal power, representing the instant power availability. In applications where speedy power requires, such as electric vehicles or grid storage systems, the knowledge of SOP is crucial for power management.
$$SoP(t)=\frac {P_{max}(t)}{P_{nominal}(t)} \times 100 [\%]$$
Methods for SOP Estimation
Multiple techniques, each having different challenges and precisions can be used to calculate the SOP.
Voltage-Based Method: The correlation between the open-circuit voltage and the available power is the basis of this technique. However, due to the parameters like battery aging and temperature effects, it may not be so accurate.
Coulomb Counting Method: By considering the battery’s internal resistance and the highest discharge current, this method can be expanded for SOP evaluation. Coulomb counting method is also used in SOC estimation. However, in this method, frequent calibration is needed and can result in error accumulation with time.
Electrical Equivalent Circuit Models: By considering its internal resistances and capacitive effects, these models replicate the battery’s behavior. The available power can be calculated by solving the equal circuit equations.
Machine Learning Techniques: The relationship between the SOP and multiple measurable parameters like voltage, current, temperature, and aging factors can be learned by these methods. Machine learning offers very precise SOP evaluation with adequate training data.
Applications And Importance Of Accurate SOP Estimation
For the effective functioning of battery-powered systems, precise SOP evaluation is critical. It ensures optimal performance during acceleration or regenerative braking, and can assist in handling power distribution between multiple systems in an electric vehicle. The precise SOP can help in handling the highest load requirements and avert unforeseen power shortages for a grid storage system. Moreover, it offers assistance in handling power-needy applications and expand the battery’s lifespan in portable electronics.
Consequently, better power management, optimized performance, elevated battery life, and increased user experience can be attained due to the capability to precisely evaluate the battery’s SOP. As a result, in battery management systems, the investigation of increased SOP calculation continuously remains an active area.
Other Estimation Parameters
Run Time, Charge Time, Instantaneous Power
Apart from SOC, SOH, and SOP, other evaluation factors such as run time, charge time, and instantaneous power are frequently used in battery management systems.
Under particular operating conditions, the time when a battery can constantly deliver power is known as run time. In applications like portable vehicles, or portable electronics, where users ought to be aware of the battery's leftover charge and its recharge time, this factor plays a pivotal role.
Under particular conditions, the charge time refers to the total time required to charge a battery from an empty state to its full capacity. The battery charging time is an important parameter in user convenience and functional readiness, for applications like electric vehicles.
Considering numerous factors such as the current SOC, temperature, and the battery’s health, the amount of power the battery can deliver at a particular time is denoted by instantaneous power. For applications having fluctuating load demands, such as power equipment or electric vehicles, where the ability to offer a power burst for a short period can be mandatory, this factor serves a vital role.
Applications for Enhanced Estimation Parameters
The information given by a BMS can be further enriched by these modern factors and improving the capability to optimize the safety, performance, and life of battery systems. With the assistance of run time evaluation, end-users can plan their usage and prevent unpredicted power cut-offs, critical in medical equipment, unmanned aerial vehicles (drones), or portable electronics.
In electric vehicle charging stations or solar power systems, charge time estimation contributes to infrastructure planning. Users can plan their activities around charging, and utilities can handle power grid requirements more productively with correct charge estimations.
Lastly, high-power applications need instantaneous power estimation. For instance, an estimation of available power assists with powertrain control, optimizing performance and efficiency in an electric vehicle. Also, the rapid changes in demand, allow the system to revert effectively to the grid storage system.
In general, these improved estimate parameters provide a more thorough comprehension of a battery's status and potential, enabling more complex control techniques and providing users and system operators with more thorough and beneficial information about their battery systems.
