Power Management for IVI Systems
Energy Consumption in IVI Systems
In-vehicle infotainment (IVI) systems are getting more complex, adding more features like media playback and advanced connectivity choices. As a result, these systems are using a lot more power. A full understanding of how much energy they use not only guarantees peak performance but also protects the vehicle's main purpose, which is to move around.
Power Requirements for Different Components
The IVI system is made up of different parts, and each one needs a different amount of power to work.
Display Screens: High-definition screens are often built into modern IVI systems. Some of these screens, especially those that are bigger or use OLED technology, can use a lot of power.
Processors and Memory: The central processing unit (CPU) and graphics processing unit (GPU) are the IVI system's brains. They can use a lot of power, especially when doing heavy jobs like media decoding or real-time navigation. Similarly, RAM and storage options use power, even though they usually don't use as much as other parts.
Connectivity Modules: Features like Wi-Fi, Bluetooth, and cellular communication need their own chips and antennas, and they all use power based on how they're working and how much data they're sending.
Audio Systems: High-fidelity speakers and amps are necessary for a full sound experience, but they can use a lot of power, especially when the volume is turned up high.
Sensors and Cameras: A lot of IVI systems have cameras built in for things like video calls and augmented reality guidance. Even though these and any other monitors add to the power needs, they are only a small part of the total.
By knowing how much power each part uses, planners can decide how to best use resources to make sure that the most important functions get enough power while also making the system as efficient as possible as a whole.
Table 1: Example of IVI Power Consumption Distribution in Modern Vehicles
Power Estimates for the Electronics Found in Infotainment Systems
Component Power Cost
Header unit CPU and GPU for real-time communication (infotainment gateway) and user-interface applications 400W to 500W
Audio system (premium) 250W
Digital signal processor (DSP) 100W
Flexible three-display concurrency (1080p center console, 720p60 navigation window for instrument cluster, and 540p60 HUD) 80W to 120W
Wi-fi 20W
The table shows that the total amount of power used is about 1kW, with the stereo system and header unit making up the majority of that. For a standard 12V setup, this is equal to about 84A of load current. The total current can drop to 21A if all the parts are converted directly at 48V.
Impact on Vehicle Battery Life
The combined power use of IVI systems can put a lot of stress on the car's battery, especially when the engine is off and the car is in "accessory" mode. For regular gasoline-powered cars, using the IVI system a lot without the engine going can drain the battery faster, which could shorten its life and make the car impossible to start.
Electric vehicles (EVs) have a primary traction battery and an auxiliary battery that powers electronics. However, if the auxiliary battery is charged from the primary traction battery when the vehicle is still and its voltage is too low, it can lead to a shorter range after a lot of use.
Also, high-power draws that happen often and last a long time can make batteries die faster. As a result, IVI systems provide many useful and convenient features; however, it is important to know how they use energy and balance their use with the overall health and functionality of the car.
In the sections that follow, we'll talk about ways to manage and reduce these power needs so that IVI systems work at their best without affecting the performance or longevity of the car.
Power Management Strategies and Techniques
IVI systems are getting more complicated and full of features all the time, so strong power management techniques are more important than ever. Power management that works well keeps vehicle parts in good shape, keeps batteries healthy, and in the case of electric vehicles, can even help the total driving range. It is possible to make IVI systems use less energy without affecting their functionality by using advanced methods and strategic design principles.
Energy-Efficient Design Principles
Power management that works well starts with the planning phase. Putting in place basic rules that are designed to save energy can have a big impact on how much energy an IVI system uses generally.
Component Selection: Choosing low-power processors, energy-efficient memory solutions, and power sources as components can cut power use by a large amount. It is best to choose parts that meet current energy-saving standards or have power-saving modes built in.
Optimized Software: Using software that is designed to work with certain hardware can save a lot of power. This includes using simpler ways to code, making methods work better, and getting rid of background processes that aren't needed.
Sleep and Standby Modes: To save energy, putting parts to sleep when they're not in use can be enforced strictly. As an example, if the user is only listening to music, non-essential parts like the screen can be muted or turned off.
Adaptive Brightness: Systems for screens that change the brightness based on the amount of light in the room can save a lot of power.
Dynamic Power Allocation and Scaling
Real-time power management methods can make energy efficiency even better than design principles alone.
Dynamic Voltage and Frequency Scaling (DVFS): DVFS changes the voltage and frequency of a part (like a CPU) depending on what the job needs in real time. The part runs at a lower voltage and frequency when it's not doing much, which saves power. In order to use DVFS, both the CPU and its power source need to be made to work with it.
Load Balancing: As jobs are efficiently split between multiple cores or processors, load balancing can lower the peak power need of any single core. This method can not only save power but also make the system more efficient.
Context-Aware Power Management: The system can handle power before the user even knows it by looking at things like the user's driving mode, the time of day, or how they usually use the device. For example, if the car is stopped and the engine is turned off, some less important functions may go into a low-power state to save battery life.
Component Power Gating: Turning off the power to parts or subsystems literally when they're not in use is called a component power gate. A lot of energy can be saved by separating and blocking off parts of the IVI system that aren't being used. But things like state retention, wake-up time, and control hardware overhead need to be thought about to make sure power gating works right.
Finally, as IVI systems become more important to modern driving, the amount of power they use will naturally become a focus for improvement. These systems can provide many benefits without putting too much stress on a vehicle's power resources thanks to their innovative design and flexible control methods. In later parts, we'll talk about how to keep these systems safe and make sure they have power, which will make them both efficient and reliable.
