External Factors
External factors that cause AC line disruptions have a substantial impact on power system reliability and quality. Lightning strikes and grid faults are the two most common external causes of disturbances. Understanding these factors is crucial for developing preventative measures and guaranteeing the stability of power systems.
Lightning Strikes
One of the most dramatic and damaging external sources that disrupt AC lines is lightning strikes. Lightning affects electrical infrastructure, including transformers, power lines, and substations, and can briefly cause very high voltages.
Figure 7: Lightning overvoltages
Impact: Lightning strikes can cause electrical fires, damaged components, and burnt cables as their direct effects. Furthermore, a lightning strike's surge can travel along power lines and produce voltage spikes that can harm electrical equipment and stop service across a large region.
Protection Measures: Power systems contain surge protectors, lightning arresters, and grounding devices to help lessen the effects of lightning strikes. These devices are intended to safely channel surplus energy to the ground, away from crucial components of the power system.
Grid Faults
system faults are any abnormal condition within the power system that prevents the regular flow of electricity. These can include line-to-ground and line-to-line issues, equipment and operational failures. Grid faults frequently cause unexpected voltage fluctuations, power outages, and cascade failures throughout the network.
Causes: Physical damage from external conditions to electricity lines or equipment, poor maintenance, old infrastructure, and interference from wildlife are common causes of grid failures. Faults can also result from human mistakes during system upgrades or maintenance procedures.
Impact: Depending on the fault's location and type, different grid faults have different effects. Localized blackouts, voltage dips, and, in extreme situations, extensive power outages impacting huge geographic areas are typical outcomes.
Management Strategies: In order to control and lessen the impact of grid failures, grid operators employ a variety of strategies. These include automatic switching systems that can redirect electricity around impacted regions, strong grid design that limits the impact of a fault to a small area, and real-time monitoring systems that can swiftly discover and isolate faults.
Internal Factors
Internal power system components, namely motor starting and equipment switching, can play a major role in AC line disruptions. Usually appearing as transients, harmonic distortions, and voltage fluctuations, these disturbances have the power to affect the overall electrical system's reliability as well as performance.
Equipment Switching
In electrical systems, switching operations refer to connecting or disconnecting circuits or pieces of equipment from the power source. The abrupt shift in load conditions might cause problems in this process.
Mechanism: Transient voltages and currents are produced when electrical equipment is turned on or off. These transients can travel across the electrical supply and impact other connected devices. The degree of the disturbance is typically determined by the type of the load and the system's capacity.
Figure 8: Switching overvoltages
Impact: Switching between pieces of equipment can result in surges and sags, which can trip sensitive equipment or cause lights to flicker. Revering big motors or capacitors can greatly impact power quality in industrial environments.
Mitigation Strategies: One way to lessen the impact of equipment switching is to install surge protectors, use soft starters for large equipment, and time the operation of heavy gear carefully. Disturbances can also be isolated by reworking the power system to incorporate circuits specifically designed for heavy loads.
Motor Starting
Starting huge motors is a major cause of internal disturbances in power systems, especially in industrial applications with high inductive loads.
Mechanism: When an induction motor is started from a standstill, it draws a large inrush current, which is often twenty times (or more) the average operating current. This enormous initial current might result in a considerable voltage drop across the system, affecting other devices connected to the same power source.
Figure 9: Motor inrush current
Impact: The voltage drop brought on by a motor starting might result in undervoltage conditions, which can interfere with operating procedures or damage or malfunction delicate equipment. Frequent disruptions can also cause equipment to age more quickly and require more maintenance.
Mitigation Strategies: Reduced voltage starts, such as star-delta starters, variable frequency drives (VFDs), or soft starters, can assist regulate inrush current and lessen the load on the power system. Furthermore, enhancing system architecture to boost resilience and capacity can assist absorb the additional demand without causing substantial disruptions.
Environmental Factors
Environmental elements such as electrical noise and electromagnetic interference (EMI) or radio-frequency interference (RFI) substantially impact the quality and stability of alternating current power systems. These disturbances can disrupt the regular operation of electronic equipment, resulting in failures and decreasing the overall efficiency of electrical systems.
Electrical Noise
Random, unpredictable variations in electrical impulses inside power lines are called electrical noise. It is frequently made worse by certain environmental factors and can originate from both internal and external causes.
Sources: Fluorescent lights, arc welders, and other industrial equipment that produces sparks or employs variable speed motors are common sources of electrical noise. Furthermore, power surges from other devices connected to the same network or lightning strikes can cause electrical noise to be generated in power lines.
Impact: Electrical noise can create errors in delicate electronic equipment, corrupt digital communications signals, and result in data loss or system failures. Additionally, it can conceal the existence of other kinds of disruptions, making diagnosis and mitigation more difficult.
Mitigation Strategies: Techniques like shielding and grounding are frequently used to reduce electrical noise. Noise can also be reduced by using twisted pair cables for signal wiring and filters to purify the power supply. In order to prevent crosstalk and interference, power connections and data transmission lines must be kept well apart.
EMI/RFI Interference
The electromagnetic fields generated by one electronic equipment interfering with another's operation by conduction, coupling, or radiation are known as electromagnetic interference (EMI) and radio-frequency interference (RFI).
Sources: Numerous gadgets, such as microwave ovens, mobile phones, and radio transmitters, can produce electromagnetic interference (EMI/RFI). Natural sources might include atmospheric disturbances other than lightning, including solar flares, whereas industrial sources could include motors and generators.
Impact: EMI/RFI can disrupt the regular operation of electronic equipment, causing data errors, signal loss, and operational failure, especially in sensitive instruments. These disruptions are especially problematic in businesses that rely on precise electronic instruments, such as aircraft, medicine, and communications.
Mitigation Strategies: One of the best ways to reduce EMI/RFI is by shielding sensitive components by covering them with conductive or magnetic materials that reflect electromagnetic fields. Using EMI filters and properly grounding equipment also helps lower its vulnerability to electromagnetic disturbances. Furthermore, EMI/RFI issues can be avoided early on in the design process by employing techniques like differential signaling and meticulous layout planning.
