EV6631H-L-00A
The EV6631H-L-00A is an evaluation board designed for the MP6631H, a three-phase brushless DC (BLDC) motor driver with integrated power MOSFETs. The MP6631H drives a three-phase BLDC motor with a single external Hall sensor or three external Hall sensors. The peak phase current is up to 3A across the 3.6V to 35V input voltage (VIN) range.
The MP6631H controls the motor speed via the pulse-width modulation (PWM) signal or the DC signal on the PWM/DC pin with closed-/open-loop control. The device features a built-in, configurable speed curve function. It also features a sinusoidal drive for maximum torque while minimizing the low-speed ripple and noise across the full speed range.
The MP6631H provides rotational speed detection. The rotational speed detector (the FG/RD pin) is an open-drain output. It outputs a high or low voltage relative to the Hall comparator’s output. Direction control is achieved via the DIR pin’s input.
Full protection features include input over-voltage protection (OVP), under-voltage lockout (UVLO) protection, locked-rotor protection, over-current protection (OCP), and thermal shutdown.
The MP6631H is available in a QFN-26 (3mmx4mm) package.
- 3.6V to 35V Operating Input Voltage (VIN) Range
- Up to 3A of Peak Phase Current
- Integrated 160mΩ High-Side MOSFETs (HS-FETs) and Low-Side MOSFETs (LSFETs)
- Sinusoidal Drive
- Supports 0V to 1.2V DC Input or 1kHz to 100kHz Pulse-Width Modulation (PWM) Input
- Supports Triple-Hall or Single-Hall Element Differential Input
- Closed-/Open-Loop Speed Control
- Direction/Brake Input
- Power-Save Mode
- 0.5s/4.5s Lock Protection
- Over-Current Protection (OCP)
- Single-Pulse or Triple-Pulse FG Output per Electrical Cycle
- FG Signal: Rotational Speed Indication
- Soft Start (SS) for Low Noise and Current Overshoot
- Available in a QFN-26 (3mmx4mm) Package
EV6631H-L-00A
