- MPQ8113-AEC1
MPQ8113-AEC1
The MPQ8113 and MPQ8113A are low-cost, unipolar, high-side current-sense amplifiers. The devices operate from a 2.7V to 60V supply, and typically consume a 300μA current. They are ideal for today’s automotive systems, industrial supplies, and systems where battery/DC current monitoring is critical.
High-side current monitoring is especially useful in battery-powered systems, since it does not interfere with the ground path of the battery charger. The common mode input voltage (VIN) ranges between 0V and 60V, with a high 700kHz bandwidth, which makes these devices well-suited for inside control and short-circuit protection (SCP) loops.
The MPQ8113 directly converts a differential VIN to a voltage output with integrated internal common input resistors and a load resistor. The MPQ8113 has a 50V/V gain. The MPQ8113A converts the differential VIN to a current output. This current is converted back to a voltage with an external load resistor. The MPQ8113A has an adjustable gain based on the external common input resistors and load resistor.
Both the MPQ8113 and MPQ8113A are available in TSOT23-6L packages.
- 显示更多 显示较少
- Low-Cost, Compact Current-Sense Solution
- 700kHz Bandwidth
- 300μA Typical Supply Current
- 2.7V to 60V Operating Supply Voltage Range
- 0V to 60V Common Mode Input Voltage (VIN) Range
- 0.2μA Typical Shutdown Current (ISD)
- 300μV Input Offset Voltage (VOFFSET)
- Available with Fixed 50V/V Gain (MPQ8113) or Adjustable Gain (MPQ8113A)
- Adjustable Maximum Output Voltage (VOUT)
- ±1% Current-Sense Gain Accuracy
- High-Current Sensing Capabilities
- Available in a TSOT23-6L Package
MPQ8113GJ-AEC1-Z MPQ8113GJ-AEC1-P
MPQ8113-AEC1 Resources
12V 至 48V 双向变换器系统应用 -
高端电流检测放大器产品类目 -
MPQ8112A-AEC1产品具有可调增益的 60V、高端电流采样放大器,符合 AEC-Q100 认证
MPQ8112-AEC1产品具有 50V/V 增益的 60V、高端电流检测放大器,符合 AEC-Q100 认证
MPQ8113A-AEC1产品具有可调增益的 60V、高端电流采样放大器,符合 AEC-Q100 认证
MP8110产品上管电流采样放大器
VIDEO
如何优化汽车 PCB 布局以提高EMI和散热性能视频通过本视频了解有关汽车 PCB 设计的更多信息。本视频展示了具备高性价比的双层 PCB 设计如何满足现代汽车应用严格的散热和 EMC 要求。该视频探讨了满足 CISPR25 5 级要求的 PCB 布局指南,并演示了 MPQ4323-AEC1 汽车级降压变换器如何增强性能。巧妙的元件放置和布局可以提高散热性能,并在双层 PCB 设计中实现热管理和EMI性能之间重要的平衡。敬请了解在无需额外组件或电路板空间的条件下,如何实现稳健、可靠的汽车 PCB 设计。
MPQ1918-AEC1产品100V、高频、半桥 GaN/MOSFET 驱动器,符合 AEC-Q100 认证
MPQ4576-AEC1产品600mA、60V 高效率全集成同步降压变换器,符合 AEC-Q100 认证
MPQ4573-AEC1产品60V、2.5A、全集成高效率同步降压变换器,符合 AEC-Q100 认证
MPQ8861-AEC1产品集成遥测功能的 18V、12A、高效率、宽输入范围、同步降压变换器,符合 AEC-Q100 认证
MPQ9841-AEC1产品36V/1A 低静态电流同步降压变换器,符合 AEC-Q100 认证
MPQ9846-AEC1产品36V/0.6A 低静态电流(IQ )同步降压变换器,符合 AEC-Q100 认证
MPQ4571-AEC1产品1A,60V高效全集成同步Buck降压变换器,符合 AEC-Q100 认证
MPQ4572-AEC1产品2A,60V高效全集成同步Buck降压变换器,符合 AEC-Q100 认证
MPQ2029-AEC1产品汽车级 40V、450mA、低静态电流可调输出线性调节器,符合 AEC-Q100 认证
MPM3509-AEC1产品36V,0.9A 模块,带集成电感的同步降压转换器,符合 AEC-Q100 认证
MPQ2013-AEC1产品40V, 150mA, 低静态电流线性调节器
MPQ2019-AEC1产品40V、300mA、低静态电流可调输出线性调节器
MPQ4431-AEC1产品36V、1A、低静态电流同步降压变换器,采用侧面镀锡封装
