- MPQ7210-AEC1
MPQ7210-AEC1
The MPQ7210-AEC1 is a synchronous, dual-buck LED driver designed to operate as a constant current source to drive two independent LED channels. Each channel can support up to 2A of output current (IOUT), and they can also be connected in parallel to support up to 4A of current.
The 4.5V to 60V input voltage (VIN) range allows a string of up to 12 LEDs to be connected in series per channel. When paired with a matrix manager, the MPQ7210-AEC1 can achieve an ideal architecture to drive adaptive driving beams or matrix headlights.
The safety protection suite includes a fault (/FS) pin used to report over-current protection (OCP), under-voltage lockout (UVLO), early thermal warning, and thermal shutdown. These features can be used to assist the system in meeting functional safety requirements.
An integrated 10-bit analog-to-digital converter (ADC) monitors VIN, the output voltage (VOUT), VCC voltage (VCC), and junction temperature (TJ), and logs the data into the internal registers. These diagnostics can be read back by a microcontroller (MCU) through the serial peripheral interface (SPI). The SPI can also be used to preset dimming profiles within the registers and mask undesired signals on the fault (/FS) pin.
The MPQ7210-AEC1 minimizes the need for a number of external components and is available in a QFN-26 (5mmx5mm) package. It is available in AEC-Q100 Grade 1.
- Built for Automotive LED Applications:
- Wide 4.5V to 60V Input Voltage (VIN) Range
- 2A Dual-Channel Buck
- 4A Single-Channel Buck
- ±3% LED Current Accuracy
- -40°C to +150°C Operating Junction Temperature (TJ)
- 8-Bit Analog Dimming
- 12-Bit Pulse-Width Modulation (PWM) Dimming
- Optimized for EMC/EMI:
- Selectable 220kHz, 420kHz, 1.1MHz, and 2.3MHz Switching Frequency (fSW)
- Frequency Spread Spectrum (FSS)
- CISPR 25 Class 5 Compliant Safety
- Safety Protection Suites:
- Analog-to-Digital Converter (ADC) to Monitor VIN, Output Voltage (VOUT), VCC Voltage (VCC), and TJ
- Failsafe (/FS) Pin and Registers
- Output Under-Voltage Protection (UVP)
- Over-Current Protection (OCP)
- Early Thermal Warning
- Thermal Shutdown
- Serial Peripheral Interface (SPI) with Configurable Features
- Current Limit
- Additional Features:
- Multi-Page One-Time Programmable (OTP) Memory
- Available in a QFN-26 (5mmx5mm) Package with Wettable Flanks
MPQ7210GUE-0000-AEC1-Z MPQ7210GUE-0000-AEC1-P
MPQ7210-AEC1 Resources
LED驱动器产品类目 -
OPTIMIZING HOME REMOTE CONTROLS WITH MPS PRODUCTS技术文章Infrared (IR) and remote frequency (RF) home remote controls are being used in systems such as sound systems, televisions, lighting, and other controls. These systems are becoming increasingly complex with features including voice control, connectivity, LED displays, and capacitive touch. Remote controls should be reliable, easy to use, and have a long battery lifespan. MPS provides cost-effectiv...
MPQ7228-AEC1产品16 通道灌电流 LED 驱动器,带自适应反馈控制 (AFC) 和 UART 接口,符合 AEC-Q100 标准
MPQ4425C-AEC1产品36V、1.5A、2.2MHz、高效率同步降压 LED 驱动器,符合 AEC-Q100 认证
MPQ7230-AEC1产品42V、1.2A同步升降压/ 3A 降压汽车红外 LED 驱动器,符合 AEC-Q100 标准
MPQ7200A-AEC1产品410kHz、42V、1.2A 升降压/ 3A 降压同步 LED 驱动器,带频谱扩展(FSS)功能,符合 AEC-Q100 标准
MPQ7235-AEC1产品36V, 3A汽车级同步降压红外 LED 驱动器,符合AEC-Q100认证
MPQ7225-AEC1产品具有自适应反馈控制 (AFC) 的 16 通道灌电流 LED 驱动器,符合 AEC-Q100 认证
MPQ2484-AEC1产品具有多种调光模式的 75V、多拓扑 LED 控制器,符合 AEC-Q100 认证
MPQ7200-AEC1产品42V/1.2A 升降压或 3A 降压同步 LED 驱动器,符合 AEC-Q100 认证
MPQ24833-B产品工业/汽车级 55V、3A LED 驱动器,符合 AEC-Q100 认证
MPQ7220-AEC1产品6 路、每路最大电流为 100mA 的升压 LED 驱动器,符合 AEC-Q100 认证
MPQ4425B-AEC1产品1.5A、36V、400kHz 高效率同步降压 LED 驱动器,符合 AEC-Q100 认证
MPQ4425A-AEC1产品高效率 1.5A、36V、2.2MHz 同步降压 LED 驱动器,符合 AEC-Q100 认证
MPM6010-AEC1产品集成电感的汽车级 36V、1.5A、高效率模块、同步降压 LED 驱动器
MPQ2483A-AEC1产品55V、2.5A 可调频率 LED 驱动器,符合 AEC-Q100 认证
MPQ4425M-AEC1产品汽车级高效率 1.5A、36V、2.2MHz 同步降压 LED 驱动器
MPSCHOLAR
POWER MANAGEMENT FOR AUTOMOTIVE DISPLAY SYSTEMSMPSCHOLARThe automotive sector has indisputably felt the impact of the digital evolution, transforming how information is delivered to both drivers and passengers. Modern vehicles have shifted away from conventional analog dials and indicators to embrace dynamic, multifunctional, and interactive display systems. Along with enhancing the user experience and aesthetic appeal inside a vehicle, these innovatio...
