MPQ6620A-AEC1
40V, 8-Channel Automotive Pre-Driver with Two Current-Sense Amplifiers, AEC-100 Qualified
MPQ6620A-AEC1
The MPQ6620A-AEC1 is a gate driver IC designed for automotive DC motor driver applications. It drives 16 N-channel power MOSFETs to drive DC motors or other loads.
The MPQ6620A-AEC1 integrates a charge pump to drive an external N-channel MOSFET for reverse battery protection. The high-side gate drive is generated by the charge pump, which allows for 100% duty cycle operation.
Eight configurable, internal pulse-width modulation (PWM) generators can be applied to the outputs.
Internal safety features include short-circuit protection (SCP), gate drive fault detection, slew rate adjustment, automatic dead-time control, under-voltage lockout (UVLO), and thermal shutdown.
The MPQ6620A-AEC1 integrates two current-sense amplifiers, and is available in a QFN-48 (7mmx7mm) package with wettable flanks.
  • 显示更多 显示较少 Show more
  • Integrated Gate Drive Power Supplies
  • 64mA Gate Drive Current
  • Charge Pump for External N-Channel Reverse Battery Protection
  • 8 Internal Pulse-Width Modulation (PWM) Generators
  • Two Current-Sense Amplifiers
  • Watchdog Timer
  • Low-Power Sleep Mode
  • Motor Brake in Sleep Mode
  • Motor Brake in Sleep Mode during Over-Voltage (OV) Conditions
  • Gate Drive Fault Protection
  • Short-Circuit Protection (SCP)
  • Adjustable Slew Rate Control
  • Over-Temperature (OT) Warning and Shutdown
  • Under-Voltage (UV) Warning and Shutdown
  • OV Shutdown
  • Open and Shorted Load Detection
  • Serial Peripheral Interface (SPI) Control Interface
  • Fault Indication Output
显示更多 显示较少 Show more
MPQ6620AGQNE-AEC1-Z MPQ6620AGQNE-AEC1-P
相关产品
MPQ6620B-AEC1 40V, 8-Channel Automotive Pre-Driver, AEC-100 Qualified
The MPQ6620B-AEC1 is a gate driver IC designed for automotive DC motor driver applications. It drives 16 N-channel power MOSFETs to drive DC motors or other loads.
The MPQ6620B-AEC1 integrates a charge pump to drive an external N-channel MOSFET for reverse battery protection. The high-side gate drive is generated by the charge pump, which allows for 100% duty cycle operation.
The MPQ6620B-AEC1 does not have current-sense amplifiers, and it is available in a QFN-40 (6mmx6mm) package with wettable flanks.
MPQ6620A-AEC1 Resources
了解更多我们的评估板套件
【精华帖合集】电机驱动器/传感器板块精华帖合集
MPS论坛 精华帖合集 全新上线!经过几年时间的累积,MPS论坛已经积累了许多有价值的内容,这其中包括技术分享、产品咨询、专业文章以及过往活动中的高质量帖子。它们是MPS众多帖子当中的沉淀的精华部分,解决了许多工程师的问题。 我们将这些帖子进行整合,方便大家进行检索和浏览。同时,该贴内容将不断更新。...
电机驱动器/传感器
Latest activity 4 months ago
12 回复
MA600 磁铁如何选型
一、MA600介绍 MA600是一款高精度,高带宽的磁角度传感器,采用MPS专用的SpinaxisTM 技术,直接检测外部磁场角度,并且基于TMR技术,进一步提高了精度和动态特性。MA600安装方式支持轴装和侧装,侧装时通过BCT补偿及用户校准,可以实现线性度(INL)<0.1°。 二、磁铁的选择 ...
电机驱动器/传感器
Latest activity a year ago
1 评论
【干货分享】步进电机基础知识:类型、用途和工作原理
本文将为您介绍步进电机的基础知识,包括其工作原理、构造、控制方法、用途、类型及其优缺点。 步进电机基础知识 步进电机是一种通过步进(即以固定的角度移动)方式使轴旋转的电机。其内部构造使它无需传感器,通过简单的步数计算即可获知轴的确切角位置。这种特性使它适用于多种应用。 步进电机工作原理 与所有电机一...
电机驱动器/传感器
Latest activity a month ago
22 回复
获取最新的技术资料
