- MPQ4425C-AEC1
MPQ4425C-AEC1
MPQ4425C 是一款具有内部集成功率 MOSFET的高频同步整流、降压开关模式白光 LED (WLED) 驱动器。它提供了一种紧凑的解决方案,可在 4V 至 36V 的宽输入电压 (VIN) 范围内实现高达 1.5A 的连续输出电流 (IOUT),同时具备出色的负载和线性调整率。
MPQ4425C采用同步模式操作,可在整个 IOUT 负载范围内实现高效率。其电流模式控制则提供了快速瞬态响应并使环路更加稳定。该器件还提供全面的保护功能,包括过流保护 (OCP) 和过温关断保护。
MPQ4425C只需很少数量的现有标准外部元器件,它采用节省空间的 QFN-13 (2.5mmx3mm) 封装。
- 显示更多 显示较少
- 专为各种汽车LED 应用而设计:
- 4V 至 36V 宽工作输入电压 (VIN) 范围
- 高达5A 的连续 LED 电流 (ILED)
- 以最小 100Hz 调光频率 (fDIM) 实现脉宽调制 (PWM) 调光
- 可提高散热性能的高性能:
- 90mΩ/60mΩ 低导通电阻 (RDS(ON) 内部功率 MOSFET
- 0.195V 参考电压 (VREF)
- 高效率同步模式
- 优化EMC 和 EMI:
- 2MHz 默认开关频率 (fSW)
- 全面的保护功能:
- LED 短路、LED 开路和过温关断故障指示
- 具有谷值电流检测功能的过流保护 (OCP)
- 附加功能:
- 强制连续导通模式 (FCCM)
- 内部软启动 (SS)
- 符合 CISPR25 5 类标准
- 采用 QFN-13 (2.5mmx3mm) 封装
- 采用侧面镀锡封装
- 符合 AEC-Q100 等级1认证
MPQ4425CGQBE-AEC1-Z MPQ4425CGQBE-AEC1-P
MPQ4425C-AEC1 Resources
LED驱动器产品类目 -
MPSCHOLAR
POWER MANAGEMENT FOR AUTOMOTIVE DISPLAY SYSTEMSMPSCHOLARThe automotive sector has indisputably felt the impact of the digital evolution, transforming how information is delivered to both drivers and passengers. Modern vehicles have shifted away from conventional analog dials and indicators to embrace dynamic, multifunctional, and interactive display systems. Along with enhancing the user experience and aesthetic appeal inside a vehicle, these innovatio...
MPSCHOLAR
LED DRIVERS AND POWER MANAGEMENT FOR LIGHTING SYSTEMSMPSCHOLARIn the past few decades, Light Emitting Diodes (LEDs) have seen a huge surge in their application within the automotive industry. When a voltage is applied, semiconductor diodes emit light through electroluminescence, which is the operating principle of LEDs. They are especially suitable for vehicular applications due to their small size, longevity, and efficiency. The LED assembly typically co...
MPSCHOLAR
INTRODUCTION TO AUTOMOTIVE LIGHTING SYSTEMS: EXTERNAL AND INTERNALMPSCHOLAROver the years, the evolution of automotive lighting has mirrored not only technological advancements but also the shifting landscape of consumer demands, design aesthetics, and regulatory mandates, culminating in a rich historical trajectory. Examining this path unveils how innovation, functionality, and safety considerations have collectively influenced the development of the vehicles navigating...
MPQ7228-AEC1产品16 通道灌电流 LED 驱动器,带自适应反馈控制 (AFC) 和 UART 接口,符合 AEC-Q100 标准
VIDEO
用于驾驶员监控系统的汽车级红外 LED 驱动器:MPQ7231视频本视频将带您了解MPS 的汽车级恒流同步红外 LED 驱动器MPQ7231的优势。该器件是在汽车中创建高效率驱动器监控系统 (DMS)的理想选择。MPQ7231能够优化并调节 DMS 中红外 LED 的运行,确保在任何光照条件下进行可靠的跟踪,同时对人眼安全。MPQ7231 采用先进的 BCD 技术,可最大限度地减少系统损耗并最大限度地提高效率,从而实现运行温度较低的紧凑型解决方案。该器件在人眼安全性和电磁兼容性方面实现了明显的增强,同时还简化了汽车应用的红外 LED 设计流程,并能确保符合行业标准。相关产品详情页: MPQ7231
VIDEO
自适应反馈控制汽车照明设计视频本视频探讨了如何利用多通道线性 LED 驱动器和自适应反馈控制 (AFC) 为汽车应用设计热平衡、高密度 LED 照明解决方案。现代汽车照明应用持续向具备更高密度 LED 的更小设计发展,从而创建更美观、更令人愉悦的动画和图案。但额外的 LED 会增加热负荷,而较小的电路板尺寸又会降低热负荷的消散能力, 而 AFC 则可以帮助工程师应对这些设计挑战。
REFERENCE DESIGN
MPQ7221 尾灯参考设计参考设计汽车照明应用对汽车尾灯的动态要求越来越高。本参考设计展示了一个完整的尾灯设计方案,它采用三个 MPQ7221 器件驱动 LED 灯串,用于刹车灯 (SL)、转向灯 (TL) 和侧标志灯 (SML)。 MPQ7221 是一款 16 通道恒流 LED 驱动器,它可在 4.5V 至 16V 的宽输入电压 (VIN) 范围内工作。 每个通道的 LED 电流 (ILED) 都可通过外部电流设置电阻设置,最大电流可达 80mA。MPQ7221集成了一个 I2C 接口,通过外部电阻可配置10个不同的 I2C 地址,实现丰富的动态效果。 MPQ7221 采用侧面镀锡的 QFN-24 (4mmx4mm) 封装,符合 AEC-Q100 认证。 本参考设计由一个降压变换器 (MPQ4323)、一个低压差 (LDO) 稳压器 (MPQ2013A)、三个 LED 驱动器...
VIDEO
汽车级16 通道LED 恒流驱动器:MPQ7225视频MPQ7225 系列产品可在汽车前照灯或尾灯设计中实现生动而明亮的动画效果。照明应用通常使用数百颗 LED 来实现出色的分辨率,而MPQ7225允许多达 16 个器件级联使用,最多提供256 个通道。满足了美学需求的紧凑型照明元件使 PCB变得更小,热管理也变得愈加重要。当功能安全在汽车应用中变得越来越重要时,MPQ7225 的推出可以帮助系统达到 ASIL-B级的功能安全等级。该系列产品还针对 EMC 进行了优化,可以达到 CISPR25 5级标准。 MPQ7225 能够简化您的设计,帮助您创建更高效、更稳健、更安全的汽车 LED 照明应用。 功能特性: 16 通道,每通道驱动电流高达 200mA 一次性可编程 (OTP) 存储器 可以通过外部 MCU 设置复杂动画 每通道均提供 12 位脉宽调制调光或 6 位模拟调光 侧面镀锡的紧凑型 QFN-32 (5mmx6mm...
MPQ7235-AEC1产品36V, 3A汽车级同步降压红外 LED 驱动器,符合AEC-Q100认证
MPQ7225-AEC1产品具有自适应反馈控制 (AFC) 的 16 通道灌电流 LED 驱动器,符合 AEC-Q100 认证
MPQ7230-AEC1产品42V、1.2A同步升降压/ 3A 降压汽车红外 LED 驱动器,符合 AEC-Q100 标准
MPQ7200A-AEC1产品410kHz、42V、1.2A 升降压/ 3A 降压同步 LED 驱动器,带频谱扩展(FSS)功能,符合 AEC-Q100 标准
MPQ2484-AEC1产品具有多种调光模式的 75V、多拓扑 LED 控制器,符合 AEC-Q100 认证
VIDEO
MPQ7200:适用于汽车照明应用的 3A 降压、1.2A 升降压 LED 驱动器视频MPQ7200 EVQ7200-L-00A MPQ7200 是一款汽车级 LED 驱动器,它具有 3A 降压模式和 1.2A 升降压模式,能够承受高达 42V 的负载突降和高达 150°C 的结温。MPQ7200 采用超小尺寸 3mmx4mm QFN 封装,非常适合汽车远光灯、近光灯、日间行车灯、雾灯和尾灯应用。观看本视频了解 MPQ7200 卓越的 EMI 性能、散热性能以及集成 FET 如何节省电路板空间并提高汽车照明设计的效率。
MPQ7200-AEC1产品42V/1.2A 升降压或 3A 降压同步 LED 驱动器,符合 AEC-Q100 认证
MPQ7220-AEC1产品6 路、每路最大电流为 100mA 的升压 LED 驱动器,符合 AEC-Q100 认证
MPQ4425B-AEC1产品1.5A、36V、400kHz 高效率同步降压 LED 驱动器,符合 AEC-Q100 认证
VIDEO
AUTOMOTIVE LIGHTING DESIGN AND EMI BEST PRACTICES WEBINAR视频Learn how designers can develop high power, exotic form factor and dynamic designs, but must still meet stringent EMC emissions criteria to avoid exceeding OEM limits and interfering with sensitive antennae or ADAS sensors. Review Presentation
MPQ24833-B产品工业/汽车级 55V、3A LED 驱动器,符合 AEC-Q100 认证
