- MPQ3322-AEC1
MPQ3322-AEC1
The MPQ3322-AEC1 is a 24-channel LED driver with a 24V voltage rating and maximum 100mA current sources. It is designed to drive LED backlighting, RGB lighting, and interior ambient lighting in automotive LCD panels and lamps.
The MPQ3322-AEC1 employs low headroom to regulate LED current and provides voltage feedback for the previous power stage to optimize the output voltage (VOUT) for LED strings. This helps achieve higher system efficiency.
The MPQ3322-AEC1 supports independent 12-bit pulse-width modulation (PWM) and 6-bit analog dimming for each channel via the based-controller area network (CAN) differential interface. The resistor on the ISET pin configures the maximum LED current amplitude.
Robust protections are provided to guarantee safe operation of the device. These protection modes include LED open protection, LED short protection (configurable threshold via the internal register), and over-temperature protection (OTP). All these fault statuses can be read through the CAN interface. In addition, the failsafe function ensures that the MPQ3322-AEC1 remains operating in a preset state once the communication information is lost.
The FF pin and single lamp mode (SLM) support single-IC and multi-IC applications for two fault statuses. In the event of a failure, the IC either only turns off the failed LED string or shuts down all channels if one channel fails.
The MPQ3322-AEC1 is available in a QFN-40 (6mmx6mm) package, and is available in AEC-Q100 Grade 0.
- 3.5V to 22V Input Voltage (VIN) Range
- 24 Channels with Maximum 100mA per Channel
- <2.5% Current Matching
- Low Dropout Voltage (500mV at 100mA)
- Independent 12-Bit Pulse-Width Modulation (PWM) Dimming
- Independent 6-Bit Analog Dimming
- Adaptive Voltage Feedback Function
- 2MHz Based-CAN Differential Interface
- Cascades Up to 16 ICs (Pin-Configurable Device Address)
- Improves EMI with ILED Slew Rate and Phase Shift
- LED Open and Short Protection
- Fault Indicator Signal Output
- Configurable FF Mode (FFM and SLM)
- Failsafe for Loss of Communication
- Failsafe Mode Set Function
- One-Time Programmable (OTP) Memory
- Available in a QFN-40 (6mmx6mm) Package
- Available in AEC-Q100 Grade 0
MPQ3322GQKE-xxxx-AEC1-Z MPQ3322GQKE-xxxx-AEC1-P MPQ3322GQKE-0000-AEC1-Z MPQ3322GQKE-0000-AEC1-P
MPQ3322-AEC1 Resources
MPQ3438-AEC1产品2A、10V、高效率、全集成、同步升压变换器,符合 AEC-Q100 认证
MPQ4328-AEC1产品36V、4A、低静态电流、同步降压变换器,符合 AEC-Q100 认证
MPQ4569A-AEC1产品75V、0.3A、同步降压变换器,符合 AEC-Q100 认证
MPM3551C-AEC1产品36V、3A、同步降压模块,符合 AEC-Q100 认证
MPQ4325-AEC1产品36V、5A、低静态电流、同步降压变换器,符合 AEC-Q100 认证
MPM3551-AEC1产品36V、3A、低静态电流、同步降压模块,符合 AEC-Q100 认证
MPQ4326M-AEC1产品集成输入电容的 36V、6A、低静态电流、同步降压变换器,符合 AEC-Q100 认证
MPQ4324-AEC1产品36V、0.5A 至 4A 峰值、低静态电流(IQ)超紧凑同步降压变换器,符合 AEC-Q100 认证
MPQ7228-AEC1产品16 通道灌电流 LED 驱动器,带自适应反馈控制 (AFC) 和 UART 接口,符合 AEC-Q100 标准
MPQ4324E-AEC1产品42V负载突降(Load Dump)容限、4A 峰值电流、超紧凑、低静态电流(IQ)同步降压变换器,符合 AEC-Q100 认证
MPQ4371-AEC1产品采用 ZDPTM 控制技术的 36V、6A 至 11A、低 EMI、同步降压变换器,符合 AEC-Q100 认证
MPQ4320-AEC1产品42V 负载突降容限、0.5A、低IQ、超紧凑同步降压变换器,符合 AEC-Q100 认证
MPQ4320C-AEC1产品42V负载突降容限、0.5A、超紧凑同步降压变换器,符合 AEC-Q100 认证
MPQ4321C-AEC1产品36V、1A、超紧凑同步降压变换器,支持42V 负载突降,符合 AEC-Q100 认证
