- MPM3806C-AEC1
MPM3806C-AEC1
The MPM3806C is an easy-to-use, fully integrated, synchronous step-down power module with a built-in inductor and MOSFET switches. The device can achieve up to 1A of continuous output current (IOUT), with excellent load and line regulation.
The constant-on-time (COT) control scheme provides fast transient response and eases loop stabilization. Fault protections include cycle-by-cycle current limiting and thermal shutdown. An open-drain power good (PG) signal indicates whether the output voltage (VOUT) exceeds 90% of its nominal voltage.
The MPM3806C is well-suited for a wide range of applications, including high-performance digital signal processors (DSPs), advanced driver-assistance system (ADAS) sensors, portable and mobile devices, and other low-power, space-constrained systems.
The MPM3806C requires a minimal number of readily available, standard external components. It is available in a small QFN-15 (3mmx4mmx1.6mm) package.
- 显示更多 显示较少
- Designed for Automotive Applications:
- Wide 2.5V to 5.5V Operating Input Voltage (VIN) Range
- Up to 1A Output Current (IOUT)
- 1% Feedback (FB) Accuracy
- -40°C to +150°C Operating Junction Temperature (TJ) Range
- High Performance for Improved Thermals:
- 75mΩ and 45mΩ Integrated Internal Power MOSFETs
- Optimized for EMC and EMI:
- Forced Continuous Conduction Mode (FCCM) across the Full Load Range
- 2.4MHz Switching Frequency (fSW)
- MeshConnectTM Flip-Chip Package
- Optimized for Board Size and BOM:
- Integrated Internal Power MOSFETs
- Integrated Compensation Network
- Available in a QFN-15 (3mmx4mmx1.6mm) Package
- Fixed Output Options: 0.8V, 1V, 1.1V, 1.2V, 1.25V, 1.5V, 1.8V, 2.5V, 2.8V, 3.3V
- Additional Features:
- Enable (EN) for Power Sequencing
- Power Good (PG)
- 100% Duty Cycle
- External Soft Start (SS) Control
- Output Discharge
- Output Over-Voltage Protection (OVP)
- Short-Circuit Protection (SCP) with Hiccup Mode
- Available in a Wettable Flank Package
MPM3806CGLE-AEC1-Z MPM3806CGLE-AEC1-P MPM3806CGLE-12-AEC1-Z MPM3806CGLE-12-AEC1-P MPM3806CGLE-18-AEC1-Z MPM3806CGLE-18-AEC1-P
MPM3806C-AEC1 Resources
电源模块产品类目 -
MPM3551C-AEC1产品36V、3A、同步降压模块,符合 AEC-Q100 认证
MPM3551-AEC1产品36V、3A、低静态电流、同步降压模块,符合 AEC-Q100 认证
MPM3806-AEC1产品5.5V、1A、同步降压电源模块,符合 AEC-Q100 认证
MPM3808C-AEC1产品6V、3A、2.4MHz同步降压电源模块,符合 AEC-Q100 认证
MPM3807C-AEC1产品5.5V、2A、2.4MHz同步降压电源模块,符合 AEC-Q100 认证
MPM3807-AEC1产品5.5V、2A同步降压电源模块,符合 AEC-Q100 认证
MPM3808-AEC1产品5.5V、3A、同步降压电源模块,符合 AEC-Q100 认证
MPM3515-AEC1汽车电源模块简介技术文章MPM3515-AEC1是Monolithic Power Systems(MPS)提供的一款36V,1.5A汽车级高压电源模块。该器件继承了MPM模块系列的关键优势:外形非常紧凑、易于使用,而且高性能。它可以提供高达1.5A的输出电流,并具有适合汽车应用的性能特征,包括符合AECQ 等级1认证、高达2.2MHZ的工作频率,以及在制造过程中可轻松进行可靠性检查的侧面镀锡封装。 从信息娱乐系统和智能照明,到ADAS(高级驾驶员辅助系统)和自动驾驶,随着汽车中复杂应用的日渐普及,车辆中的微处理器、ASIC和传感器数量也迅速增加。要驱动这些功能都需要电源,电路板空间因此变得弥足珍贵,而采用高功率密度的解决方案才是关键。MPM3515-AEC1模块能够以非常紧凑的外形尺寸和很少的外部组件满足这些电源需求。 MPM3515-AEC1模块比具有类似功率水平的传统分立式电源解决方案要小得多。 ...
MPM3805B-12-AEC1产品6V、0.6A、带集成电感的同步降压模块变换器,符合 AEC-Q100 认证
MEZS91603A产品双路 60W USB PD 充电器解决方案
DIY8883产品可配置 36V,3A DC/DC 降压芯片
MPM3805A-AEC1产品6V,0.6A 模块,带集成电感的同步降压变换器,符合 AEC-Q100 认证
MPM3810A-AEC1产品6V,1.2A 模块,带集成电感的同步降压变换器,符合 AEC-Q100 认证
MPM3515-AEC1产品汽车级,1.5A, 36V, 集成电感和PG功能的同步降压电源模块
