- HFG611-45
HFG611-45
The HFG611-45 is a quasi-resonant (QR) flyback regulator with an integrated GaN FET, which is suitable for high-performance and high-frequency designs.
The device is a secondary-side regulation (SSR) based primary regulator, and must work with secondary-side feedback circuitry. The higher frequency shrinks the passive component size and achieves higher power density. The HFG611-45 integrates a high-voltage start-up circuit and an X-capacitor discharger circuit, in addition to an ultra-low quiescent current (IQ) during burst mode. The no-load power consumption can be below 30mW.
The HFG611-45 adopts MPS’s patented valley lock technique to restrain the valley jumping from one to another during steady state operation and help avoid audible noise. The wide supply voltage (VCC) range makes the device suitable for applications with a wide output voltage (VOUT) range without adding auxiliary winding.
Advanced protections include primary-sense output over-voltage protection (ZCD OVP), primary-sense output under-voltage protection (ZCD UVP), VCC over-voltage protection (VCC OVP), output overload protection (OLP), internal brown-in and brownout (BI and BO, respectively), short-circuit protection (SCP), internal thermal shutdown (OTP), and under-voltage lockout (UVLO).
The HFG611-45 is available in QFN-21 (5mmx6mm) and QFN-25 (7mmx7mm) packages.
- Integrated 700V/300mΩ GaN FET
- Novel Patented Quasi-Resonant (QR) Control to Eliminate Audible Noise
- Ultra-Wide Supply Voltage (VCC) Range to Support USB Power Delivery (PD) Applications
- Built-In X-Capacitor Discharger
- Built-In, High-Voltage Start-Up Circuit
- Ultra-Low Standby Power Consumption with PD Protocol IC (<30mW)
- Peak Current Mode Control and Leading-Edge Blanking (LEB)
- Under-Voltage Lockout (UVLO), VCC Over-Voltage Protection (OVP), ZCD OVP, ZCD Under-Voltage Protection (UVP), Overload Protection (OLP), Internal Brown-In (BI) and Brownout (BO), Short-Circuit Protection (SCP), and Over-Temperature Protection (OTP)
- Available in QFN-21 (5mmx6mm) and QFN-25 (7mmx7mm) Packages
HFG611GQN-45-Z HFG611GQN-45-P HFG611GQJ-45-Z HFG611GQJ-45-P
HFG611-45 Resources
三相智能功率表应用随着消费者对能效越来越关注,三相智能电表成为智能家居的关键组成部分。三相电表使用三线制(有时是四线制),与单相电表相比,可以承受更高的负载。三相电表效率更高,并能够以恒定的速率稳定地提供功率。它通常用于功率要求高于普通住宅的商业或工业建筑,通常安装于室外用来测量能耗,因此需要准确、高效且使用寿命长。 MPS提供的产品组合包括可靠性高且经久耐用的DC/DC控制器、反激稳压器和反激控制器。这些设备通过降低成本和BOM简化设计流程,从而加快产品上市时间。 MPS卓越的解决方案结合了高效率和小尺寸封装,为设计下一代三相智能电表提供所需的一切。
便携式数据终端应用便携式数据终端(PDT)是一种通过网络远程访问和传输数据的热门设备。它们通常需要能够长时间使用,例如好几个小时;而且由于其跨行业的应用,PDT要比其他移动设备更坚固耐用,可以承受极端的环境条件。而这意味着其组件必须以较小的解决方案尺寸提供高可靠性、超低功耗和安全连接。许多便携式数据终端都集成了WLAN、2G/3G/4G/5G、蓝牙和WiFi功能,以及触摸屏控件和用户友好的界面,以轻松实现设备操作。MPS为便携式数据终端供电设计提供了一整套器件,包括变换器、稳压器、整流器、充电器、开关、背光驱动器、模块、PMIC和音频放大器,可简化设计过程并加速产品上市时间。这些器件以便携式数据终端所需的小尺寸封装提供了出色的性能、散热管理以及其他保护功能。MPS在电力行业拥有丰富经验,可确保以很低的设计成本实现更佳效率。
<70W应用AC/DC电源为各种消费类、工业和商业应用提供高效的电源转换。为满足应用中的各种法规和要求,低于70W的电源需要提供超低待机功率和高集成度。 MPS广泛的解决方案组合中包括反激控制器、反激稳压器和反激同步整流器。这些先进的设备均采用紧凑型封装,实现高效率、高可靠性和更长的使用寿命,并且通过降低成本与BOM,帮助您简化设计过程并加快产品上市时间。MPS卓越的AC / DC电源解决方案提供了系统供电所需的一切。
副边控制产品类目 -
HFG610-45产品High-Frequency, Quasi-Resonant Flyback Regulator with Integrated 270mΩ GaN FET
HFC0310A产品Configurable, Fixed-Frequency Flyback Controller Suitable for SiC MOSFETs
HFC0500产品定频反激控制器,具有超低空载功耗
OPTIMIZING HOME REMOTE CONTROLS WITH MPS PRODUCTS技术文章Infrared (IR) and remote frequency (RF) home remote controls are being used in systems such as sound systems, televisions, lighting, and other controls. These systems are becoming increasingly complex with features including voice control, connectivity, LED displays, and capacitive touch. Remote controls should be reliable, easy to use, and have a long battery lifespan. MPS provides cost-effectiv...
HF300产品高频、理想钳位反激控制器
HFC0512产品具有超低空载功耗的固定频率反激控制器
MPX2003产品频率高达 140kHz 的一体化反激式控制器,集成原边控制电路和副边同步整流驱动器
MPX2002产品集成原边控制电路和副边同步整流驱动器的一体式反激控制器
HFC0100产品准谐振反激控制器
HFC0650产品High-Frequency, Quasi-Resonant Flyback Controller
HF920A产品具有输入欠压保护功能的 900V 定频离线调节器
HF920产品900V 定频离网调节器,具有超低待机功耗
HF500-7产品定频反激式自供电调节器,支持多模式控制和过功率线路补偿
HF500-30产品定频反激调节器,支持多模式控制和过功率线路补偿
HFC0310产品可调定频反激控制器
HFC0300产品可变关断时间反激控制器
HF900产品900V 离线开关调节器
HFC0511产品130kHz 定频反激控制器,具有超低空载功耗
MPXG2100产品NovoOne Family, All-in-One, SR ZVS Flyback Regulators
